I know enough that the internal audio encoder in TMPGenc isn't so great so many people use toolame or other external encoders to go from 44.1 khz to 48 khz. I was wondering how this was set up.
Thanks!
Panasonic DMR-ES45VS, keep those discs a burnin'
Go to environmental settings, choose audio engine, and load the .exe into the appropiate place.
with the newest version of tmpgenc .. the conversion tool is very good IF you set in environmental settings, choose audio tab -> advanced audio conversion instead of default .
You can always treat the audio completely separately, using HeadAC3he or Besweet to convert and resample the audio. Then you only use TMPG to mux the audio and video.
Does this mean that if my AVI allready have 48 khz TMPGEnc I will not have quality issue ?
If your audio does not require resampling, then you will not have a quality issue. If your audio is 48Khz, and your final product will be DVD, then your fine. Same applies if your audio source if 44Khz, and your end product will be VCD/CVD/SVCD. If your audio has to be resampled (say from 48Khz to 44Khz, or vice versa) then, and only then, will you notice any difference. This assumes you have a problem with the quality that TMPGenc produces in this situation. Try it first, and see if the quality is acceptable to you.
Impossible to see the future is. The Dark Side clouds everything...
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 07:46 -
encoders?
By just in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2008, 09:15 -
dvd player +dvix+usb with external 160GB external HD problem...
By spidermen in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2008, 19:45 -
What are the current encoders comparable to tmpgenc in quality?
By inuyasha in forum Video ConversionReplies: 24Last Post: 26th Jun 2007, 05:43
