I am a novice to the world of VCDs. So I could be asking some dumb questions ... Anyway, here is my question:
I captured an avi file through 1394 interface from my PAL Camcorder (SONY DCR-TRV10E). I converted it into an MPEG file (NTSC format) using TMPGENC. Thereafter I made a ".cue" file using VCDEasy and burnt it on a CDR using TEAC CD Writer. I am able to play it on any PC (by using a vcd playing software) but when I try playing on my DVD Player (Yamaha DV-S5270), it says that it does not support this type of disc. The User manual for DV-S5270 says it can play VCD !! I had purchased this DVD Player 3 years back. What could be wrong ?
If you live in a PAL territory (which I assume you do as you have a PAL camcorder) then your DVD player may not support NTSC VCDs.
Or it may not play CD-R/W discs. -
No. I live in NTSC territory.. and the DVD Player is a Region 1 dvd player and claims to also play VCDs
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
Need DVD Player that plays .avi files
By ukbsktbll in forum DVD & Blu-ray PlayersReplies: 12Last Post: 8th Mar 2009, 08:57 -
looking for a DVD player that plays it all
By gameroftheuk in forum Newbie / General discussionsReplies: 1Last Post: 6th Aug 2008, 23:45 -
I'm not sure if my DVD player plays dual layer...
By Asaad331 in forum Newbie / General discussionsReplies: 17Last Post: 3rd Mar 2008, 17:27 -
Bilingual VCD plays both languages in Media Player Classic!
By cordeliamars in forum Authoring (VCD/SVCD)Replies: 2Last Post: 27th Aug 2007, 13:25
