Hello, I have a simple question. I am thinking of importing in some Region 1 (ntsc) dvd's to play in the UK (region 2).
I have a region-free player. When i played some SVCD's with NTSC films on them, making them run in PAL made them jerky and I had to use NTSC.
My question is this,
If i get some R1 dvd's, will I have the same problem as I do with my SVCDs - will they jerk unless i set it too NTSC (my tv doesn't always like NTSC).
THankyou,
Michael
THIS WILL HAPPEN EVERY TIME YOU PLAY A NTSC DISC,TRY AND SET YOUR TV AND DVD PLAYER TO AUTO AND THIS SHOULD PLAY BACK THE REGION 1 DISC AT 29.97 FRAMES PER SECOND NOT 25 FRAMES PER SECOND AS IN PAL MODE.
IF YOU TRY TO PLAY A NTSC DISC IN PAL IT WILL STUTTER AND THE PICTURE MAY GO BLACK AND WHITE OR SIMPLY LOSE ITS COLOUR.
Converting DVDs from Region 1 (NTSC) to Region 2 (PAL)
By Astronautilus in forum Authoring (DVD)Replies: 8Last Post: 10th Feb 2012, 05:35 -
How to change a Daewoo DSL-19M1WC TV/DVD unit from region 2 to multiregion
By gcatano in forum DVD & Blu-ray WritersReplies: 1Last Post: 7th Dec 2011, 02:06 -
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 22:10 -
Converting PAL Region 2 to NTSC region 1
By bevluvsrats in forum Video ConversionReplies: 10Last Post: 21st May 2008, 10:15 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 13:58
