I recently downloaded and tried the test VCD from vcdhelp.com, only to find a message displayed, that apparently shouldn't have been displayed.
It told me that I shouldn't be seeing it because 'PBC Mode' should have been turned on. To do this I discovered I have to press the 'DISC Menu' button on my remote (to turn PBC on) then play the VCD again. This cures the problem and plays the VCD as intended.
The Philips DVD 634 does not come compatible with Photo-CDs, however a remote hack allows you to enable it. This hack works fine. However, in order to play the Photo-CD I have to turn on PBC again by pressing 'DISC Menu' then playing the Photo-CD.
My 'nag' is that every time I want to play a VCD/SVCD with menus, or play a Photo-CD, I have to enable 'PBC Mode' each time. If I insert the VCD without enabling 'PBC Mode' it just plays the movie, skipping the menu. This means if I forget to enable 'PBC Mode' each time, I miss the menu. If I insert a Photo-CD without enabling ‘PBC Mode’ it just does not play the Photo-CD. Also, enabling it each time is a bit of a drag...
My friend has a completely different DVD player (Alba 103) and it has PBC Mode permanently 'Enabled' whereas my DVD player seems to have it permanently 'Disabled'! I burn all my VCDs/SVCDs with Nero, and they work correctly on other machines.
I have two questions:
1) What is PBC?
2) Can I enable it permanently on my machine, and if so - how?
Any related tips/pointers/help very much appreciated...
Thanks, Cheekie![]()
Results 1 to 1 of 1
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 03:03 -
35 "VR Mode DVDs" made years ago-- need to finalize/make viewable
By Swarup in forum Newbie / General discussionsReplies: 10Last Post: 8th Nov 2011, 15:38 -
xvid-AVIs won't play until re-saved in "copy"-mode
By Information in forum Video ConversionReplies: 0Last Post: 5th Dec 2009, 10:03 -
Do hdtv owners use the "fill" mode to get rid of "underscan&
By yoda313 in forum PollsReplies: 20Last Post: 11th Jul 2008, 20:02 -
Decrypter "Brute Force" mode can damage the writer, or produce ba
By Bruxo in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Dec 2007, 16:26
