  1. Is there a way to convert 2 VCD's disks in to one DVD-r movie ive been trying for dayz but i cant get it to work can anyone please help????
    Keep It Brutal
    A Yellow Submarine
    Drag your AVSEQ01.dat files to your computer and use vcdgear to convert it to a true mpeg video file.
    Then use this guide to put the two parts of the movie together with TMPG http://www.vcdhelp.com/tmpgencedit.htm
    Then you can author that file as a dvd. This is sometimes called a DVD-VCD. You can look to see if your DVD player supports it by looking under the link at your left. The only problem with that is that the audio is at the wrong sampling fequency (44,100Hz) when DVD is 48,000Hz. You'll have to resample your audio if you want it truly standard.
