I have been successfully capturing MPEG2 videos and converting them to VCD format for several months. I have recently purchased (and installed) an ATI AIW Radeon 8500DV. Bundled with this card is Ulead's Visual Studio SE 6.0. After installing this software, my TMPGEnc Plus 2.5 encoder refuses to recognize any of the MPEG2 files that it was successfully using before the Ulead install.
As near as I can figure, there seems to be a codec problem here, but I don't have any idea how to fix it. I have seen many posts where both Ulead and TMPGEnc seem to be playing nicely together. Anybody have any ideas about how to fix this?
Many thanks, bigpig
Have you tried re-installing TMPGenc?
Ulead Video studio (not visual) unless you plan on using it should be un-installed. If it appears that the Ulead product is the problem even after you uninstall it, you'll have to clean the registry of most of the refrences to Ulead products. Also be sure to delete any Ulead folders on your hard drive. This is assuming you don't have any other Ulead products installed.
Sound problem with Ulead VideoStudio 11
By rogerhacker in forum Newbie / General discussionsReplies: 15Last Post: 16th Jul 2010, 19:41 -
MVK to MPEG2 - TMPGEnc
By zecaloteiro in forum Video ConversionReplies: 1Last Post: 18th May 2010, 08:32 -
Ulead VS10 sound problem
By theguy1991 in forum EditingReplies: 1Last Post: 3rd Dec 2007, 19:06 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 29th Jul 2007, 23:57 -
Trouble when saving MPEG2 Ulead VideoStudio 10
By faramith in forum Video ConversionReplies: 3Last Post: 13th May 2007, 09:17
