Which is the best media you use ? 2X, 4X, please reply. i just purchased this unit and need some good advice from the pros
Thanks![]()
Results 1 to 16 of 16
Just bought some fugifilm gonna give it a shot later tonight, I'll post back some results later.
Thanks alot,
dreadogg -
did not get the chance to burn yet, I still am reserching this, i am pretty new to all this, maybe tommarro I will attemp. Laterz
Thanks alot,
dreadogg -
Oh yea you can get those at office max for like two bucks a piece!
Thanks alot,
dreadogg -
I've used Maxells in mine, worked fine not 1 coaster. I've also used what were sold to me as princos but I belive are bulkpaq based on the media list on here that burn fine up till about 4 gig then 2 in every 3 give coasters, crappy outer rim
I'm trying some riteks they just have to come
I bought 100 pack of leda for .69 C each.. it works fine with my
pioneer a05.. burned 23 discs with no problems... I was worried that there may be problem.. but no problem at all... here the site for those who internest
http://www.shop4tech.com/user.htm?go=view_item&id=436 -
Get the new firmware (v1.21 I think it is) and you can use any media - once I ran the update program, everything I have thrown at the drive burns just fine. Often at speeds above what they are certified for. Ritek, for example, is not 2x certified but does burn at 2x.Originally Posted by phhoth-MPB/AZ
that .69 media looks cheap, I'll wait on some more testers of that brand!
Thanks alot,
dreadogg -
I'v been using the dvdpro discs here,not 1 coaster yet http://supermediastore.com/25pac47bulun.html
I also bought a 4X test pack from http://www.supermediastore.com which has like 5pcs DVD-ON 4x media and 5pcs Ritek, I receive the disc before the new year and has tried the 4x. It was great!! Finally an impressive burning speed. Have not try the ritek yet, but I was reading an article on their site, it seems that the ritek are able to burn at 2x. I'll post more once I tryout the RitekG03 media.
Does anyone know (accesscard18?) if you can burn the Leda media at 2x w/ the newest firmware?
BTW where you I d/load the newest firmware. I only see updates for the A04, but nothing for the A05. -
Tried Memorex first and it started pixelating 1/2 way through the movie on my player. Then tried Verbatim (on sale at target for 9.99 for a dvd-r 3 pak) and it worked great. Will buy a bulk pack of Riteks soon.
any dvdr with the ritek dye is a good bet!!! stay away from tdk dye as they fail!!
princo
ritek
pioneer
verbatim
they are all fine & dandy & work...
cheaper disks write but dont play!!
traxdata are probably ya best bet on a disk as they work everytime
Kev! -
For the Aussies I suggest Melody 2X ($2.50) in bulk. Works all the time. Datastream is another good buy for 2X. Avoid any generic plain ones that the vendor tries to pass off as unlabeled TDK's.
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Windows Media Center dvr-ms format
By todds1 in forum SVCD2DVD & VOB2MPGReplies: 16Last Post: 15th Sep 2007, 03:37 -
DishNetwork DVR thru Media Center to DVD. Is there a better way?
By nate78 in forum Newbie / General discussionsReplies: 2Last Post: 13th Sep 2007, 14:32 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 12:23
