*update,found out that im using a drx-500ul , not 500a,even nero says that.. (PS! I didnt buy this burner,my dad did,and he lent it to me, so i assumed what nero said was right...therefore,i believed it was 500a)
Hello!
I'm having lots of trouble with Sony DRX-500UL.
First, I cant burn DVD R- media with it, YES, i do have
the latest, at least the version that supports my burner.
I've tried with *Accu Dvd media, and Ritek DVD Media.
None of them work. Yes, I also have the latest firmware.
I have a desperate hope of getting help from anybody,
so i copied and pasted the logfile into this post.
Its not only Nero that I'm having trouble with, also DVDdecryptor
does not work.
When i tried it last time (and I've tried it 5-6 times),
it found the dvdmedia, and was about to start, but, for some odd reason
it just did not start. And Im very happy that it didnt do the same
shit as Nero, cause nero flamed me 6/6dvds.
The only program that works, is the Veritas software
that follows the burner, but, thats stupid, cause I like Nero a lot
more, it has more features, and i need to use dvd-decryptor.
PS! Nero did work with Verbatium 2.5x R+ media!
I'm hoping to get answers and a sollution, Sangofe.
Dont forget to read the Nero log file!
"Windows 98 4.90 (ME)
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 08.06.2000 17:00:00
Nero Version: 5.5.9.17
Recorder: <SONY DVD RW DRU-500A> Version: 1.0f - HA 2 TA 0 - 5.5.9.17
Adapter driver: <USBMPHLP> HA 2
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI, detected: USB
CD-ROM: <MEMOREX DVD-MAXX1240> Version: 0.36 - HA 1 TA 0 - 5.5.9.17
Adapter driver: <ESDI_506> HA 1
Bus Type : default (0) -> ATAPI, detected: ATAPI
SONY DVD RW DRU-500A (Target 0, J: Autoinsert On, DMA ?, Disconnect ?, SyncDataXfer ?
Memorex Twelve MAXX 1032 (Target 0, H: Autoinsert On, DMA On, Disconnect ?, SyncDataXfer ?
MEMOREX DVD-MAXX1240 (Target 0, I: Autoinsert On, DMA Off, Disconnect ?, SyncDataXfer ?
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 34603008 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261548kB)
Free physical memory: 33MB (33948kB)
Memory in use : 51 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: On
30.12.2002
ISO compilation
21:36:20 #1 Text 0 File Isodoc.cpp, Line 7050
Iso document burn settings
Determine maximum speed : FALSE
Simulate : TRUE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
21:36:20 #2 Text 0 File Reader.cpp, Line 115
Reader running
21:36:20 #3 Text 0 File Writer.cpp, Line 126
Writer SONY DVD RW DRU-500A running
21:36:20 #4 ISO9660GEN -11 File geniso.cpp, Line 4485
First writeable address = 0 (0x00000000)
21:36:20 #5 Text 0 File Burncd.cpp, Line 3597
Turn on Disc-At-Once, using DVD media
21:36:30 #6 Text 0 File ThreadedTransferInterface.cpp, Line 659
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 1858032 (1858032) = #1858032/412:53.57
relocatable, CD pos for caching/writing not required/required, no patch infos
21:36:30 #7 Text 0 File DlgWaitCD.cpp, Line 203
Last possible write address on media: 2298495 (510:48.45)
Last address to be written: 1858031 (412:55.56)
21:36:30 #8 Text 0 File DlgWaitCD.cpp, Line 208
Write in overburning mode: FALSE
21:36:31 #9 Text 0 File DlgWaitCD.cpp, Line 1420
Recorder: SONY DVD RW DRU-500A;
CDRW code: 00 00 00 00; CD manufacturer unknown
ATIP Data: ?
21:36:31 #10 Text 0 File ThreadedTransferInterface.cpp, Line 811
Prepare recorder SONY DVD RW DRU-500A for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 -489410560
21:36:31 #11 Text 0 File ThreadedTransferInterface.cpp, Line 659
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1858032 blocks [SONY DVD RW DRU-500A ]
21:36:31 #12 Phase 24 File dlgbrnst.cpp, Line 1574
Caching of files started
21:36:31 #13 Phase 25 File dlgbrnst.cpp, Line 1574
Caching of files completed
21:36:31 #14 Phase 32 File dlgbrnst.cpp, Line 1574
Simulation started at 2x (2*760 KB/s)
21:36:31 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1953
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
21:36:31 #16 Text 0 File Mmc.cpp, Line 16752
Set BUFE: supported -> ON
21:36:31 #17 Text 0 File Cdrdrv.cpp, Line 7293
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
21:39:35 #18 Text 0 File Scsicmd.cpp, Line 1935
SCSI timeout (2), 180000ms, CDB Data[hex]: 2A 00 00 00 08 C0 00 00 20 00 00 00
21:39:35 #19 CDR -1175 File Cdrdrv.cpp, Line 1302
Internal trace
Command timeout occured: timeout 180000ms, counter 1
CDB Data: 0x2A 0x00 0x00 0x00 0x08 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
21:39:35 #20 SCSI -26 File Cdrdrv.cpp, Line 1333
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x022F0000
Status: 0x00 (0x02, SCSI_PENDING)
HA-Status 0x00 (0x00, OK)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
Sense Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
21:39:35 #21 SCSI -26 File Cdrdrv.cpp, Line 1388
Sense Code: 0x00
Sense Qual: 0x00
21:39:35 #22 CDR -26 File Writer.cpp, Line 334
SCSI/ATAPI command timeout error
21:39:36 #23 Text 0 File ThreadedTransfer.cpp, Line 219
all writers idle, stopping conversion
21:39:36 #24 Text 0 File ThreadedTransfer.cpp, Line 213
conversion idle, stopping reader
21:42:47 #25 Phase 34 File dlgbrnst.cpp, Line 1574
Simulation failed at 2x (2*760 KB/s)
21:42:47 #26 Text 0 File Scsicmd.cpp, Line 402
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.90.3000, size=19278 bytes, created 08.06.2000 17:00:00
File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 11.09.2002 18:01:04
File 'IoSubsys\CDFS.VXD': Ver=4.90.3000, size=59141 bytes, created 08.06.2000 17:00:00
File 'IoSubsys\ESDI_506.PDR': Ver=4.90.3000, size=25365 bytes, created 08.06.2000 17:00:00
File 'IoSubsys\USBMPHLP.PDR': Ver=4.90.3000, size=4861 bytes, created 08.06.2000 17:00:00
File '..\System32\Drivers\1394bus.sys': Ver=4.90.3000.1, size=44240 bytes, created 08.06.2000 17:00:00
File '..\System32\Drivers\Ohci1394.sys': Ver=4.90.3000.1, size=49488 bytes, created 08.06.2000 17:00:00
File '..\System32\Drivers\Sbp2port.sys': Ver=4.90.3000.1, size=36336 bytes, created 08.06.2000 17:00:00
File 'IoSubsys\Disktsd.vxd': Ver=4.90.3000, size=18663 bytes, created 08.06.2000 17:00:00
File 'IoSubsys\USBMPHLP.PDR': Ver=4.90.3000, size=4861 bytes, created 08.06.2000 17:00:00 (Adapter driver for rec)"
Results 1 to 24 of 24
Your problems is
try the latest driver at Adaptec
http://www.adaptec.com/worldwide/support/driverdetail.html?sess=no&cat=/Product/ASPI-4...=aspi_v471.exeTo Be, Or, Not To Be, That, Is The Gazorgan Plan -
thanks for the link, but, it didnt solve my problem.
I still have the same error. -
You have multisession set to true. Most standalone DVD players do not read multisession disks. You want multisession to be false (you're burning the disk once) and Finalize = true (you're done with this movie).
Panasonic DMR-ES45VS, keep those discs a burnin' -
I don't see ahead WinASPI entry... My log file...
Do you have it connected through external USB enclosure ???Windows XP 5.1
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 10:03:20 AM
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 6/25/2002 5:34:54 PM
Also not sure about this ?
YOUR ->30.12.2002
YOUR ->ISO compilation
MY ->23.11.2002
MY ->UDF/ISO compilation -
Quote:
Windows XP 5.1
-Yeah, this is the USB2.0 Burner.
YOUR ->30.12.2002
MY ->23.11.2002
pY ->UDF/ISO compilation
Hm, I guess it because i downloaded the most recent nero today that its the same.
And, I turned off multisession in the options, yet, nero thinks that i want to do multisession... -
Is this an external USB/Firewire Drive? That's a completely different set of problems.
yeah...
its External, USB 2.0 Burner...
edit/added info: I do have the latest firmware... -
Sony DRU-500A is not external. Did you put it in extrenal enclosure ? Based on your log file, it might be problem. Put it back to PC IDE port.
What about that ahead WinASPI entry missing ? -
the "Sony DVDRW DRU-500A" I have is an external burner that works with the USB system, I have USB 2.0
Hm, i dont even know how i set it to that...
About the ahead winaspi, i dont know -
Go to Nero.com and get ASPI if you don't have one. (Read instructions)
Again... Did you place it in enclosure ? Or it came like that ?
Sont DRX-500UL is external version of 500A -
Hm,i had allready downloaded that file from nero.com
It was the one they say to copy and paste in nero folder, oh well, that didnt work.
That winaspi.dll file that is located at Nero...It doesnt has a thing to do with Nero 5.5+ versions, its for upgrading Nero 4...
"How can I update Nero 4.0 from previous Nero Releases (older than 4.0.8.3)?
Nero Releases older than 4.0.8.3 cannot be installed under Windows 2000,
because the driver within this Nero Releases cause that Windows 2000 does not boot anymore.
Please download Nero Demo 4.0.9.1 from our website
Please install this Nero Release
Please download the WNASPI32.DLL file and follow the above mentioned instructions.
Now start Nero. Now you can enter the serialnumber you got for unlocking the demo.
Now you have a full working Nero Release.
Also, i have WinME, not 2000. -
Sorry, but what does "enclosure " mean?
I'm norwegian and there are certain words i do not know in english...
Edit:
In nero, and veritas, both programs says the burner is DVD RW DRU-500a burner.. -
Look here... http://www.meritline.com/firusben.html
You have some Private Messages from me...
WNASPI32.DLL http://www.nero.com/en/content/c1023694368810.html#11 -
Fix your header (subject) you have Sony DRX-500UL
And I believe problem is in your USB connection. But I might be wrong. -
I had the same problem with the Sony Recorder made a number of coasters, It was the USB connection Nero does not work with a USB connection I switched to the Firewire connection and now everything is OK Try switching to Firwire The Sony takes both Inputs
sangofe Posted: Dec 31 11:38
Edit:
the word [/b]enclosure means it it is in a seperate case, Enclosure is something that encloses someting. I hope this helps.
JD bon jour, Chaio, saluteJD tinkerer pushin' 60,
A real Life Enemy of the State, see Fed case #01-40080, Detroit.
Computers, Electronics, vintage Audio, Photography Film/digital/3D, N-Scale RR, ,
AKA the "Infamouse Joe Walker" ,Join the Navy & see (1/2) the world. -
Hello!
After changing the USB to firmware, and installing the updated
winasp32.dll file, i got it working !! ( I dont know
why i had trouble installing this updated file, but,
I finally got it working after trying loads of times!)
Even though I now can burn without erros-
I still have a strange error...
Every time I load nero, and windows media player, i get this error:
NeroApix:
Could not open driver. Trying system ASPI.
(take a look at the screencapture I made):
http://www.dbz-dvd.com/%7Edbgtdub/neroapix.jpg
This is not an error that corrupts the burning, but, still, its
annoying.
At last but not least, i would like to thank all of you a LOT for
helping me out with this, you've really helped me a lot
That error message looks like now you have truble with Nero ASPI driver. Try to reinstall (copy to Nero dir) it. Or maybe even reinstalling Nero.
well,i have tried several times to unistall nero,and use the aspi nero file like it says at nero webpage
I have a Sony 500UL and it works fine without an External Enclosure. I am curious as to what this Enclosure is supposed to do....just dissipate heat? is it really necesary?
External enclosure is good only for internal drive (HD, CD-ROM, DVD burner...). He was saying that his is 500A which is internal (IDE). So for UL... you already have enclosure done by manuf...Originally Posted by 4k4e4n4
I have the DRX-500UL and was making only coasters with several types of media, and using Nero, DVDDecryptor, Veritas, and others.
Even though I have a USB 2.0 port, and it should be compatible, it wasn't.
I made sure it wasn't buffer underflow problems, and disabled all antivirus software to be safe.
Once I switched to the firewire port, everything worked perfectly with all the above listed programs plus others.
You may want to try the firewire port if you have a connection on your PC.
Yamaha DRX-730 HACKS
By math_ferreira in forum DVD & Blu-ray PlayersReplies: 8Last Post: 3rd Jun 2025, 07:44 -
ProCoder 3 dosn't export mp4 AAC audio
By SheFeiLong in forum Video ConversionReplies: 0Last Post: 27th Oct 2011, 05:53 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
help Drx-710ul Doesnt Recognize Dvd+r
By aqua in forum DVD & Blu-ray RecordersReplies: 3Last Post: 23rd Jun 2008, 23:57 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11
