Movies are PAL 25 frames
WONDER BOYS, PULP FICTION
i use DVD2DVDr 132
turn on progresive lines
DVD autor with IFOEDIT
and movie after authoring is like i didnt turn on PROGRESIVE LINES.
where is mestake
thanx
AGAIN: movies are PAL 25
Pioneer DV 717
Pioneer DVR 108
Sony RDR-GX3 -
well first did you check with biteratecalculator or any other tool if they were progressive or not??
[-Neoh*-]|[-Cheers-] -
no
i make many movies without any changes with dvd2dvdr132 and ifoedit
explain please
thanxPioneer DV 717
Pioneer DVR 108
Sony RDR-GX3 -
well you should always check with a prog to see if the movie is PROGRESSIVE or INTERLACED.
Personaly i use bitratecalculator. you load it up, and load a .vob from the main movie, then check on the left down side, there is a part with info like, linear or non linear, first frame, interlaced or progressive, etc. Then I put my encoding settings accordingly to it.[-Neoh*-]|[-Cheers-] -
where to download bitrate calc and OK
when i get this infos (progresive or interlaced or whatewer) what next
please helpPioneer DV 717
Pioneer DVR 108
Sony RDR-GX3
what would the best setting for me for Handbrake ? plz answer
By FaisalKhan in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 08:38 -
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 10:58 -
Hard question that nobody can answer: Why LCD > CRT?
By SignedupGuest in forum Newbie / General discussionsReplies: 31Last Post: 20th Jul 2007, 11:34 -
Need someone who has seen Transformers The Movie(animated) to answer Q?
By Denvers Dawgs in forum Off topicReplies: 10Last Post: 27th Jun 2007, 20:42 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
