OK, I followed the VCD tutorial on VCDhelp.com and i converted everything correctly. I burned it with Roxio's Easy CD Creator the Video CD. WORKED in the past. Well. I burned it and all.. then today when I put the cd in the DVD player (Toshbia SD3750) it doesn't even play makes weird ass noises and then a PBC things comes on the players LCD screen. I tired 3 different brands of media... Whats wrong?
VCDer (trying)
Easy CD Creator is not known for being very good at VCD authoring...
Have you tried Nero or VCDEasy?
Regards.Michael Tam
w: Morsels of Evidence -
Yeh, I tired VCDEasy, But it made a Bin and cue file. I got some error when trying to get the CDRAIO to work.
VCDer (trying) -
Does VCDEasy say that your ASPI layer is valid (bottom right hand corner)?
If not, then close VCDEasy, and download and install ForceASPI ( http://www.vcdhelp.com/tools ).
After you install, REBOOT immediately.
Then, try again.
CDRDAO will work with essentially ALL modern internal IDE burners.
Alternatively, you can use CDRWin to burn the CUE/BIN images. Nero can sort of do it too (but it is not generally recommeneded unless you can't get CDRDAO working).
Regards.Michael Tam
OK, did that, install the FORCE thing now when I burned I get a DISC ERROR? I followed teh VCDEasy tutorial exactly from this website?
VCDer (trying) -
Comes to look at it, VCDEasy didn't even burn anything onto the CD.
VCDer (trying) -
Does "ASPI Layer looks valid: Yes" come up on the bottom left hand corner of VCDEasy?
Regards.Michael Tam
Video where speech is quiet and noises are loud
By A Traveller in forum Software PlayingReplies: 14Last Post: 12th Oct 2011, 11:39 -
my current camera (jvc gr dv500) is messed up. making noises n weird lines
By bojadada in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 10:09 -
Hard drive noises?
By Hank Kinsley in forum ComputerReplies: 6Last Post: 12th Dec 2008, 06:58 -
Strange Audio noises..
By Superstar24 in forum Newbie / General discussionsReplies: 3Last Post: 29th Nov 2008, 02:12 -
noises in audio
By Driftking978 in forum AudioReplies: 1Last Post: 29th Apr 2008, 10:51
