Until recently i used to be producing SVCDS at good quality, holding 37 mins of film onto each 80 min CDR. now i have changed to TMPEG and get 57 mins onto a CDR at better quality. i atchieved this by using the variable bit rate function (VBR). i know that by changing this one setting i am nowe producing XVCDS. however, my question is....
just how compatable is this XVCD with a stand alone DVD player?? i love getting 57 mins onto a cdr but if i am going to dramatically reduce compatability then i dont think it is worth it!
i am in the UK and so use the Pal format if this helps at all. thanks for all your healp & advice!
If you're making them as VCD (MPEG-1) with VBR, many players seem to have problems. SVCD allows VBR encoding, so if you encode to SVCD MPEG-2 with 2-pass VBR there are no issues with standards compliance.
cool, cheers a lot m8, i am using mpeg 2 and so that means better quality and no probs with compatability! cheers m8
Common Codecs and xVid / DivX compatability
By anonymous_whatever in forum Newbie / General discussionsReplies: 25Last Post: 20th Feb 2012, 18:53 -
Sony WEGA KE-42M1 Compatability with Panasonic Blue Ray
By Worlcup in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Dec 2011, 00:14 -
Video Playback, File Compatability
By TomFriedmann in forum Newbie / General discussionsReplies: 0Last Post: 14th Dec 2011, 09:14 -
Sony Z7 compatability
By 392 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 4th Nov 2009, 23:06 -
Compatability of DVD+R DL media with LG LDA-831??
By jamiemark in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Mar 2008, 11:07
