Hi
Can anybody help me. I tried to make a backup of a DVD and it needed to be re-encoded. I used DVD-decrypter only main movie, then ifoedit0.95 to strip it but it was still too large. Then I used rempeg2 and remuxed it with ifoedit and the backup was perfect. The only problem was that rempeg didn't use both my processors to encode so it took 15 hours to encode.. Then I would try to use Tmpgenc to re-encode it and here the problems starts:
1. I open dvd2avi and save the d2v and ac3 file.
2. Start tmpgenc -> selecting d2v file -> Setting bitrate -> load tmpgenc file from ifoedit and 10 hours later I get a fine m2v file.
3. I start ifoedit -> load vts****.vob. -> vobmenu -> select remux -> select m2v file BUT when i hit OK ifoedit freezes and are not responding anymore...
Any bright soul out-there that can help me with this problem??
best regards
Hells Elf
Remuxing an m2v created by Tmpeg in Ifoedit if it worked you would find the audio out synch. Use Ifoedit.95 in it's DVD author mode. Load the m2v and ac3 and create your DVD. It also allows you to preserve cell/chapter points.
Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
By 2397to2997 in forum Video ConversionReplies: 12Last Post: 18th Aug 2010, 15:42 -
Problem editing IFO using IFOedit
By cooldude859 in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2009, 16:54 -
m2v + ac3 problem?
By just in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2008, 17:24 -
Problem with .m2v
By KameronK in forum Video ConversionReplies: 2Last Post: 6th May 2008, 10:39 -
Menu swapping with IfoEdit - Problem solved
By Bingo-days in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 03:07
