  1. i have picturetotv and can not burn at all i get it to create movie after it makes 2 mpeg files it shuts down.. and when i try to burn it says cant read video file..then video cd creation has errors any help please?
  2. can no one answer this question?
  3. I'm not sure I am following your question. Are you trying to burn from PictureToTV or are you trying to create a BIN / CUE pair to use in another burner (Nero, etc.)?
    I could not burn directly from PictureToTV, however I was able to generate a BIN / CUE pair by clicking on 'Burn CD' and then making sure that the 'Generate new video' option is checked, not the 'Generate new video and burn into CD'. The BIN / CUE file should be placed in the directory spedified in the 'Save to, then burn from video file' box.
  4. it is woprking now i don't know why but it is now creating bin files so thanks
