Is it possible to intersperse a "photo cd" section between videos and burn to a (S)VCD? For example.. In one timeline, have some captured video, then a series of pictures, then back to video, then some pictures.. well you get the idea..
And if so, what software or how...
thanks.. and forgive me if this is a newbie question, but I have been unable to find a discussion on the topic.
Thanks!
ArcSoft Showbiz,Ulead Videostudio 6,Pinnacle Studio 8 or use Windows Movie Maker(poor quality)to author and TMPGEnc to render to (S)VCD.
Yes.
Best way is to use high resolution MPEG stills for the images on the VCD.
You can chain a series of <playlist> (for the video clips) and <selection> together to get the effect that you want.
For more info on how the XML stuff works:
http://www.michaeltam.com
For the best VCDImager-based VCD authoring system, VCDEasy:
http://www.vcdeasy.org
Regards.Michael Tam
w: Morsels of Evidence
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 09:53 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27
