Hi, have a problem backing up my dvd of minority report, had dvd 4 xmas from the mrs and always try to back up my originals cos my 4yr old daughter likes to think that my dvd's r hers, tried backing up with dvd2svcd, all goes well until it brings in the programme bbMPEG, then comes up with error - Unable to find audio, has n e 1 come across this problem, have backed up many other of my originals without n e problem at all.
Many Thanx
Results 1 to 10 of 10
Hi,
I dont have the problemm you have but ive backed-up minority report using this guide.
http://digital-forums.com/dvd2dvdr/
Good luckTo all those past and present. All those that have fought for our freedoms. God Bless. Those of you that are fighting now,
keep your heads low. Those of you back home hold your heads high. -
Hi md_mushroom
You did not really say if you are doing a DVD 9 to DVD5+/- R or what, but if you back up a lot of DVD 9 to DVD 5 this how I do it. Minority Report BU great with this method, as well as all others I have done.
SnH
Dvd 9 to 5
www2.whidbey.net/mnms/ -
I just backed up Minority report to a single DVD-R with the following sequence:
1. rip with CloneAD XP
2. run through DVD2AVI
3. Run through TMPGenc
4. Run through SpruceUP
5. Burn with Gear Pro DVD.
I end up with a nice 4.5 Gig DVDMy system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
2x512 MB DDR 500 ram
WinXP Pro
ATI Radeon X800pro
5x120 GB Western Digital ata100
TDK Velocd 48x16x44
Sony 8x DVD burner -
Originally Posted by md_mushroom
hi m8, i also use dvd2svcd all the time... over 30 rips question is ..did u use dvd2svcd 2 rip the film onto your h/drive ? myself i use dvd decrypter first so i can get a chapter file , but more important.. i can then check the vobs 2 c if all is ok.
sounds like u have not selected an audio stream 2 me
It's ok fellas, sussed it out, i used smartripper to rip to h/drive, somehow it didn't rip audio, just left pc on overnight and it took 8 hours all together to rip. Using AMD Athlon xp1800, 512 pc133mem and win ME, thanx for all your help, will b more careful in future, many thanx
Max -
I just read this thread, HUH?
OK, I did Minority report and there were MANY ways to attack this puppy. For all those using DVD2SVCD in DVD mode, WHY? If thats the way you like to do things, then fine. Stop reading here.....
Option 1.
Use DVD2SVCD. ReEncode.
Option 2.
Stream rip this pig, use IFOedit. Keep the Original Video (100%) perfect. Use the Dolby AC3 Surround track. (Kill the 5.1)(Too Big) Create new IFO's. Transcode a VOB. Done.
Option 3.
The way I did it, I followed Option2, but I wanted the original menu, so that I have a the original Chapter Menu. SO, hack off the stupid credits, about 2 min into the last chapt. The Credits are NOT on a Chapter entry point...So use vStrip to perform a cut. This leaves the final chapter link correct in the main menu.
Use IFOupdate to correct the .ifo tables.
Fix the menu IFO to Jump in the ROOT MENU (Use IFOedit.. First play PGC)
Then I transcoded the last VOB down using ReMPEG to make it fit, its now 4,705,000,000. Fits by 2 Mb, due to Lead-in, Lead-Out of burner.
So now, I have a copy that doesnt show any WARNINGS, starts at the main menu and all the Original menu Chapter screens work perfect.
This isnt exactly a Step-by-Step, but for the willing, its a step in a new direction.
VidHack -
Originally Posted by Smurff
Those figures equate to the video at 23.97fps and the audio at equiv of 25 (hench the difference).
check your settings. never used that program before so can't really advise you on that though, but have done it myself once. Had sound at Pal 25fps and video at NTSC 29.97 cause I accidentally hit the wrong option!
Cheers
D
This Virtualdub crash report mean anything to anyone?
By brassplyer in forum EditingReplies: 4Last Post: 30th Jan 2011, 19:35 -
How do I report a bug in SUPER?
By rafwuk in forum Newbie / General discussionsReplies: 2Last Post: 9th Apr 2009, 09:39 -
EyeTV 250 Plus Capture Report
By quicksilverg4 in forum MacReplies: 0Last Post: 10th Aug 2008, 13:34 -
Eclipse report says 0 errors or warnings. . .
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 17th Jun 2008, 13:48 -
Do you allow your dvr to report your viewing habits?
By yoda313 in forum PollsReplies: 7Last Post: 28th Apr 2008, 13:55
