how do i burn these files. fireburner sucks it test burns but doesn't actually burn. i have cdrwin 5 but theres no place for cue and bin files. i tried the older one and it didn't work said something about no cd-rom recording devices... so can't use that unless u guys can help me out. thankx
Just use a tool called isobuster.. open up the bin file extract the AVSEQ01.DAT file rename it movie.mpg REMEMBER the Mpg extension and it extrscts the Dat file into a mpg that can be burned with nero as a vcd that should be it enjoy
EvErY0nEs A HaTeR BuT mEE! -
You can use nero, just select to create new cd from an image. then select the cue file and hit burn. very easy using the wizard.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 21:33 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
