I'm copying DVD using
-> Smartripper - DVDx 2.0 - AVISynth server 0.59 - TMPGEnc 2.xx
What I found out was that if I was going to make a 1-VCD movie (so I play with bitrates to do that) MPG-1 (non-standard) videostream is not working anymore !!
in version 2.53 a movie with bitrate about CBR 800 is about 1,2 Mb in size.
in version 2.59 a movie with bitrate about CBR 800 is about 1,7 Mb in size !!
All settings are the same, except for some environmental options that do not excist anymore in 2.59.
Why...can anybody explain that ?
MPG-1 size and MPG-1 VCD-1 complaint (non-standard) should have the same size is it not ? Know it seems that the last option in v2.59 stays on 1150 kbps. Why the change with the version ? I can't use V2.59 anymore...![]()
Other people seem to be having that problem w/ 2.59 also
http://www.vcdhelp.com/forum/viewtopic.php?t=133293
read last post they used a different setting -
Thanx for replying..
I will give VBR with MPG-1 a try...but this is just to stupid to be true..
btw..I've also used templates from www. KVCD.net and they gave same results (playing with CQ and VBV buffersize to influence total size).
______________________________________
Just a ...... taking advice from another ......
I have been noticing the same thing, or at least something similar - I have an 80:42 minute movie that I am trying to get on 1 CD...I am using the following settings:
Source video: 16:9NTSC 704x480 29.97fps
Resulting Video: 4:3NTSC 352x240 23.976fps
Constant Bitrate: 1050
VBV Buffer size: 40
Inverse telecine (to convert to 23.976)
44100KHz, 224 Kbps Audio
then I began encoding...it came out to 805 MB - so I tried to lower the bitrate to 950 - same size...so i lowered it 500 just to see what was up...still came out to 805 MB - Why wont it change?
According to the wizard, using a Bitrate setting of 1150 produces the 805 MB. So I lowered it to 1050 and it reports that it SHOULD kame a file that is 730 MB (or close to that) but I always wind up with an 805 MB file....how can I change this?
Please help,
GH -
It has been an often reported problem with 2.59. Appears to be a muxing bug...
I would suggest that you use 2.58 or an older version for now.
Regards.Michael Tam
w: Morsels of Evidence
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32 -
By mobie29 in forum Authoring (DVD)Replies: 4Last Post: 7th Apr 2010, 21:30 -
By mdw46 in forum Authoring (DVD)Replies: 2Last Post: 29th Nov 2009, 16:18 -
.srt sometimes works.. sometimes doesn't
By jaxwire2003 in forum SubtitleReplies: 3Last Post: 19th Feb 2008, 09:03
