Well, I'm doing something wrong. No matter what I set the average bitrate to, I get the same file size. I am using MPEG-1 Video-CD (non-standard) in the System tab, too.
If someone can help me I certainly would appreciate it. I can't figure out what I'm missing.
Here are my settings:
Video tab
352 X 240, 29.97 fps, 2-pass VBR (min=0, avg=500,max=1150)
//I've tried all sorts of numbers for avg bitrate.
System tab
If anyone wants the rest of the settings I can offer them; I didn't think they mattered here. I left them as default.
Thanks in advance.
Dale
Results 1 to 9 of 9
As far as i know VCD's do not support Variable bitrate. change to a constant bitrate and then try again.
The reason I did that was because I followed the "The newbies guide to fitting a movie on one CD using TMPGEnc" located here:
http://www.vcdhelp.com/forum/userguides/84759.php
According to that, at least if I understand it, you can use different bitrates.
Thanks for the reply!
Dale
[/url] -
Okay , yes vbr would be considered XVCD, You could also lower the audio to get lower size just a little bit. Not sure why your having problems if you changed to videocd (nonstandard) give the constant bitrate a try and see if your file size changes to what you wanted.
I did also try the Constant Bit Rate (CBR) as you suggested. Same thing. I haven't tried messing with the audio yet...it's at 224, but something just isn't right.
The MPEG Tools settings on the file menu...should I mess with those as well? I don't really understand what they are for.
Lots of users have had success with this...I can't figure out what I'm doing wrong.
Thanks,
Dale -
I had the same problem with TMPGEnc 2.59
Use Mpeg-1 System (vbr) instead. -
OK...I wanted to follow up on this.
I did get it to work as far as MPEGing it. The file size was what I wanted. However, when I went into Nero to burn it, Nero treated it as a much larger file, showing it exceeding the CD's capacity line. So it really didn't work for me.
Finally, I found a version 2.58, did a non-standard Video CD, and this worked. I was able to get the file size I wanted, and Nero burnt it without problem.
Dale
Can I change the file size of a video?
By ivansmom in forum Newbie / General discussionsReplies: 4Last Post: 3rd Feb 2011, 20:04 -
Change bitrate of LPCM 5.1 ch ( audio file after demuxing )
By wisitch in forum AudioReplies: 3Last Post: 8th Apr 2010, 13:09 -
How do I change an .H264 TS video file's bitrate?
By bubbrubb in forum Video ConversionReplies: 1Last Post: 15th Feb 2010, 14:47 -
Can't change the file size
By spiro murray in forum ffmpegX general discussionReplies: 3Last Post: 11th Mar 2009, 22:48 -
Change the file size ?
By sat-jokar in forum Newbie / General discussionsReplies: 1Last Post: 27th Feb 2009, 19:32
