what is the best way to join 2 Avi files without lossing sound or video?or re encoding
i have tried so many programs but non of them "make me happy"...
Use VirtualDub with the settings on direct stream copy. The "Append Video Segment" will join the clips
Hmmm - maybe you downloaded a 2 segment divx avi from some p2p network?
You can't be sure the encoding of both halves are the same.
Since you have WinXP have you tried Windows Movie Maker Beta 2 (www.microsoft.com/windowsmedia)?
Otherwise you might copy the specs of movie1 from the virtualdub info screen and compare to movie2. You'll have to decide if you want to have virtualdub tweek one or the other to match. If there is variable bitrate encoding that may be problematic.Panasonic DMR-ES45VS, keep those discs a burnin'
Join AVI files??
By bagmand22 in forum Authoring (VCD/SVCD)Replies: 16Last Post: 14th Feb 2010, 03:42 -
join several avi files
By hilario in forum EditingReplies: 2Last Post: 13th Nov 2009, 12:49 -
Join AVI files together ?
By terryfox in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2009, 22:56 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16 -
Join 18 .avi files with VirtualDub
By nlec in forum EditingReplies: 8Last Post: 16th Jun 2007, 00:32
