  1. Does anyone has the hacking code for the philips MX3700D
  2. None listed - did you read the comments on the 3800?
    http://www.vcdhelp.com/dvdhacks
    Panasonic DMR-ES45VS, keep those discs a burnin'
  3. I tried but without success, but I notice that
    PLAY 159 PLAY shows the 25 number in the left video exactly some
    hack description, maybe play 159 will work but I need the correct code.
  4. I tried with tray out press 1 2 3 OK, then I receive the firmware,
    VER0528 MX3600, I donīt know if is possible to upgrade this firmware ???
