I want to use NeroVision, but am having trouble with burn a DVD from any kind of mpeg-2 file(either SVCD or DVD compliant), because I always get a runtime error 226 message and my computer freezes.
I got Nero's mpeg-2/SVCD plugin and then later got their mpeg-2/DVD plugin also(which apparently includes the SVCD plugin in it's program).
I'm wondering IF the problems I'm having authoring/burning DVD's from mpeg-2 capped files now is because of a possible conflict between the 2 plugins that might duplicated in some way and messing things up.
Is there a way to Uninstall the SVCD plugin now? (I don't see anything about it in my Add/Remove panel)
Just how do you remove a plugin, if you want to? (I'm using Win98SE)
Results 1 to 1 of 1
Need plugins
By IT learner in forum EditingReplies: 6Last Post: 12th Sep 2011, 09:49 -
Cannot uninstall Nero 9
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2009, 07:31 -
vd plugins
By uglijimus in forum Video ConversionReplies: 3Last Post: 9th Oct 2009, 06:27 -
How do you uninstall WMP 10?
By rayden54 in forum Software PlayingReplies: 5Last Post: 8th Jan 2008, 14:59 -
How can I uninstall Huffyuv?
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Jun 2007, 09:55
