I downloaded Crouching Tiger, Hidden Dragon in .avi format. The picture is good and all, but the sound isn't working. I'd like to burn it to VCD, but no point burning it without sound. I used VirtualDub to check the audio, but I have no idea what it means
===Audio Stream===
Sampling rate: 44100Hz
Channels: 2(stereo)
Sample precision: 16-bit
Compression: Unknown(tag 0161)
Preload skew: 10 samples (0.00s)
# of frames: 155357
Min/avg/max/total frame size: 372/372/3720 (56442K)
I'd be very happy if anyone here could help me
Your audio is probably AC3 as AC3 can show up as unknown in VirtualDub.
:P
You could install "Nimo's Codec Package" as it comes with an AC3 audio decoder and other codecs too. It's in the Tools section.
Hope That Helps!!!:P
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Fixing bad resampled DVD audio
By silverwolf0 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2009, 10:59 -
nero with bad audio quality?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 1Last Post: 3rd Sep 2007, 04:07 -
bad audio frame
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2007, 14:37 -
Bad Audio problems
By Shaba1 in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2007, 00:02
