Hi. I´ve ripped a DVD with SmartRipper and I've used DVD2AVI to make the d2v file (to use as video file with TMPEnc). I've made also the demux of the audio from the VOB files with DVD2AVI and then converted it to MPEG Multichannel with HyperCube Transcoder. The problem is that I've to make an multiplex of the video an audio strams in TMPEnc (wich is easy), but I can't do a simple multiplex as I can't obviously put the entire film as one file (because it can't fit in one CD). So as I've to cut it with TMPEnc (making 3 or 4 mpg films to fit in 3 or 4 CD's), I can't simply multiplex the unique audio file that HyperCube trancoded. If I use this file in TMPEnc as audio does it conserve the 5.1 multichannel or it is converted as an ordinary stereo prologic file (as TMPEnc only have stereo in audio options and not multichannel)? How to solve this problem as I really want to make SVCD's with multichannel from DVD (because my DVD player supports MPEG Multichannel Streams as it has the MPEG Multichannel icon marked on it). So, not taking advantage of this is frustrating!
Please help me solving this problem.
Salutations,
Antioch
>If I use this file in TMPEnc as audio does it conserve the 5.1 multichannel ?
Yes. -
To Hypercube
No. It will be converted in a stereo file. It only remains 5.1 if you do multiplex (as it says in your web site). -
sorry, I understood:
"I use this file in TMPEnc as audio "
"I multiplex this file in TMPEnc as audio"
If you put a Multichannel MPEG file as input in TMPGENC encoder,
you will lose Multichannel part. And this is a strange idea to do that...
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Restoration of multichannel video tape
By lucky65 in forum RestorationReplies: 4Last Post: 14th Nov 2008, 09:29 -
multichannel audio with multicamera setup...
By foler in forum AudioReplies: 4Last Post: 7th Nov 2008, 02:57 -
Rotel 7.1 MPEG Multichannel Decoder....any others?
By Disco Makberto in forum AudioReplies: 9Last Post: 30th Nov 2007, 06:23 -
multichannel audio videoconference with VLC
By grmary in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2007, 17:24
