how do i sucessfully encode an xvid avi ti vcd
please can anyone help
Firstly make sure you have the Xvid codec installed (obviously
), You might need an AC3 audio codec too. Tmpgenc should then have no problems encoding the files....
I have a movie file that needs the Xvid codec, which I installed and the file plays fine in WMP.Originally Posted by mh2360
However, when encoding this file I initially got sync problems. I solved this by using VirtualDub to extract the audio into an uncompressed .wav file and then loading the .wav file as audio source in TMPGEnc.
So far so good, but this surprisingly introduced a new problem: I now get an MPEG file with fine audio but partially missing video! Every few seconds, the screen goes black for a short while, then the video comes back, disappears shortly after, etc. -
cheerrs for all the info guys
i think i have sorted it okay
i have sucessfully encoded cd1 of die another day dvd screener
My experience is that converting xvid's to Mpg's, done with Panasonic are easier to do, 99 % succesfull. Just a note........ for all the rest........'course I use Tempgenc.
Encoding Xvid in 50mbps?
By 24fps in forum Video ConversionReplies: 11Last Post: 15th Aug 2011, 20:37 -
Xvid encoding
By fester77 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2011, 08:19 -
How to get Xvid encoding in VirtualDub
By Dr_Asik in forum Newbie / General discussionsReplies: 9Last Post: 25th Feb 2010, 11:31 -
Quick XViD Encoding?
By shorto in forum Newbie / General discussionsReplies: 5Last Post: 22nd Mar 2008, 04:54 -
Encoding with Xvid.
By Felo in forum Video ConversionReplies: 1Last Post: 26th Aug 2007, 01:38
