Hi Everyone,
I tried to merge 3 (a, b, c) files (MPEG1) with TMPGEnc. All 3 files are the same. MPEG1, same bitrate, same resolution and same audio-sample.
When I try to merge the files TMPEnc gives the error, that the files are not compatible an deletes the two last files.
If I first load b and c and a at last, it deletes the last file with the same error.
Can please anyone help me?
Best regards
Buffist
get the proggie bitrate viewer (listed in tools over <----there) and load up the files one at a time and check their properties, you'll find something different somewhere....
Try mergeing with DV Tool,I find it much more forgiving than Tmpeg.
I'd have a look at the three files. They are exactly the same (incl. the constant bitrate of 1843). I don't know what to do.
I've read in this forum to export the three files to DV with ULEAD. What sort of file will result by exporting as DV? Can I encode this file with TMPEnc? What properties does it have to have?
What I wanted to do is to cut the commercials out of one with ULEAD recorded file. This gives me three cutted files which I want to make a SVCD of. Does anyone know another way to do this?
I tried to cut the big file with TMPGEnc but it does'nt cut frame-exactly.
TMPGEnc, Vobsub and mpg files as source
By kubak in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2009, 16:52 -
[help] TMPGENC DVD AUTHORING v3 - unable to convert to MPG
By meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 04:47 -
MPG with TMPGEnc
By koberulz in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 17:43 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 10:07 -
TMPGEnc not working.. what else is good for avi to mpg?
By andre477 in forum Video ConversionReplies: 10Last Post: 21st May 2007, 01:52
