I've used a process of taking a 1.2 GB mpg movie and splitting it in 2 for two SVCD disks that was really very simple. There were 6-1GB mpg files and once the orginal IFO files were created in IFOedit, I separated the mpg files into 2 folders and added the IFO and BUP files to both folders. Then I used Nero to burn two SVCD disk. Both worked great,...no problems. This was for a VHS quality move I took off a DirectTV.
The question is,... I've ripped a DVD via Decryptor and the files are too large to fit on one DVD+R, even after stripping out everything. I don't want to go through the process of stripping, re-encoding, authoring, and then burning one disk,... too much work. The question is, can I divide up the vob files from my orginal rip, put them in two folders, copy over the duplicate IFO and BUP files and then just burn two DVD+R. I figure that DVD+R are cheap enough now and I don't have the time or the tools to re-encode the entire DVD, this simple way would really be nice,... if it works. Anyone have an answer to this simple question.
Thanks in advance.
"Technology",...It's what keeps us all moving forward.
I know IFOedit will just split them,... I've done it before. But it takes a lot of time,...hours to do it, and I've got sooooo much work to do I don't want to take the time if it is going to end up on two DVD+R disk anyway. It takes just seconds to move the VOB's to a diffenent folder.
But, will it work, has anyone tried it. I guess the next best thing to do is to try it to a DVD+RW and see if it works."Technology",...It's what keeps us all moving forward. -
HMMMMM..hours to just split a movie?????? it only takes me about 15-20 min on a intel 1.5 ......how fast is ur machine????
i can split and burn a backup in 2.5 hours or so...that INCLUDES 2 hours just in burning discs
later baked -
Yes my machine is rather slow, 750 MHZ AMD. Plus I'm limited on disk
space because I have so may movies ready to be split and burn.
Anyway, I tried to "Divide" the VOB's and that won't work. Nero reads the file and stops with an error, "VOB VTS_04_3.vob" is missing". It did give me the choice of continuing but warned of possibility of making a bad disk. I will try it anyway with a DVD+RW and see what happens.
If you estimate is right, it should take me about 1+hour to rip a 7.5GB movie, then about 1 hour each to burn. I'll give both a try.
Thanks"Technology",...It's what keeps us all moving forward. -
Bstansbury - I don't believe you can just move the VOB's to a different directory. You will need to use IFOEdit or DVDXcopy. You can keep the original menus too.
_________________
Peka + Drugs =
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 11:37 -
DVD9 to DVD9 1:1 Copy
By Lastman369 in forum DVD RippingReplies: 5Last Post: 12th Jan 2010, 13:48 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 19:17 -
DVD9 to DVD9 blank
By cadlewv in forum DVD RippingReplies: 7Last Post: 27th Dec 2008, 18:15 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 20:34
