Ok, here's the deal. I burned a VCD with nero, the encoding went fine and so did the burning process. I created the menu and the backgrounds and all that crap. I had burned 3 Thundercats episodes to the cd wanting to watch them on the 61" widescreen tv rather than the 21" monitor. I took the "vcd" out and put it in the dvd player and it read the disc, the menu popped up and then nothing happened. Every button I pushed gave me the damn little STOP symbol and the menu just sat there, looking at me funny. I used Nero simply because it auto converts all the files to be the correct format, I do not want to convert the files and use another type of software. Please advise. Thanks ahead of time.
Zerocool27x
Mess with the best, die like the rest!
Nero encoding sucks. You really should use just TMPGEnc to encode them.
Also, not sure about the menu problem. I use VCDEasy, and the menu's it builds you must push a number for each selection.
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Nero 7.7.5.1 start burning at 1x!?
By arminio in forum Authoring (DVD)Replies: 23Last Post: 5th Jan 2009, 06:50 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 23:04 -
Nero burning DVDs from the outside in?
By 2prfm.com in forum Authoring (DVD)Replies: 12Last Post: 19th Jun 2008, 22:47 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 09:35
