whats the diff between those 2 types?
That information is found in the DVDR section of this site.DVD-R and DVD-RW
DVD-R/W was the first DVD recording format released that was compatible with standalone DVD Players.
DVD-R is a none rewriteable format and it is compatible with about 87% of all DVD Players and DVD-ROMs.
DVD-RW is a rewriteable format and it is compatible with about 68% of all DVD Players and DVD-ROMs.
DVD-R/W supports single side 4.7 GB* DVDs(called DVD-5) and double side 9.4 GB* DVDs(called DVD-10).
These formats are supported by DVDForum.
DVD+R and DVD+RW
DVD+R/W has some better features than DVD-R/W such as lossless linking and both CAV and CLV writing.
DVD+R is a none rewritable format and it is compatible with about 81% of all DVD Players and DVD-ROMs.
DVD+RW is a rewritable format and is compatible with about 68% of all DVD Players and DVD-ROMs.
DVD+R/W supports single side 4.7 GB* DVDs(called DVD-5) and double side 9.4 GB* DVDs(called DVD-10).
These formats are supported by the DVD+RW Alliance.
Both formats are likely to loose as neither are very compatible with DVD players. Also price and recording capacity are going against them. Look out for high cap Blue Laser DVD's in the next few years.
DVD-R and DVD+R are only interim formats. They will not make people junk their VHS machines. -
I would say that you are very wrong DVD+R is easly the best, the only thing going against it at the moment is the price of media but what do you expect when it's the newer of the two.DVD-R = Win
DVD+R = Lose
Seriously. Stick to DVD-R.
There is no point in waiting for the next format to come out, thats like saying "Look out for translucent disk in the next few years" when Blue Laser DVD comes out. Also there may be more than one standard when blue laser comes out too.Look out for high cap Blue Laser DVD's in the next few years.
I would suggest that you get a DVD recorder which can record on to both standards, DVD-R(W) and DVD+R(W) like the "Sony DRU-500a".
Best Regards
Barry
difference between burning DVD-4,7 GB and DVD-8GB
By michcio in forum DVD RippingReplies: 3Last Post: 2nd Jul 2009, 11:56 -
Commerical DVD v/s DV->DVD quality difference ?
By Movie-Maker in forum Newbie / General discussionsReplies: 6Last Post: 16th Aug 2008, 15:21 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 21:06 -
The difference between mpeg-2 and mpeg2-dvd in Premiere and the use in DVD
By umforrest in forum Video ConversionReplies: 5Last Post: 16th Jan 2008, 21:36 -
What is the difference between a cd/dvd duplicator and cd/dvd burner
By wan2no in forum Newbie / General discussionsReplies: 7Last Post: 5th Nov 2007, 21:12
