how to put 2 movies on one dvdr?
i encoded 2 movies and they are small enough to fit on one dvdr, but have no idea how to do it.
can some one please tell me of a simple way to do it?
is there a guide somewhere that shows how to put 2 movies on one dvdr with a simple menu to choose between the two?
i tried to use spruceup, but cant figure out how to make a menu with it. not sure how to link the buttons to the right movie..
sonic dvd seems alot easier, but it only let me use the video file, it wont accept .ac3 audio format.
do i need to convert it to other format, or should i combine the audio and the video first?
what do i need to combine the video and audio files so i can used it with sonic dvd with out loosing sound quality?
i got so many questions. i wish i had a faster system. it would have been easier to just try different things. but with my 900 mhz duron it takes forever to experiment. cant afford to make a lot of mistakes. -
I'm going from memory......but here goes...
In Spruce, you import your video assets and they will appear in the list of available videos (third tab I believe).
Import a picture or use one of the included ones to create a meny screen.
Drag two buttons to the menu screen and position them how you see fit.
Drag your two video's (i.e. two movies) and place them after the menu screen on the bar at the bottom.
Go back to the menu screen and right-click one of the buttons and point it to one of the movie files. Do the same for the other button.
Select preview to see if it all worked.
Like I said, that was from the top of my head....it might not be exactly like that but it might be close enough that you can work the rest out.....failing that, go look up the Spruce guide on doom9.org.
Hope this helps... 8)
p.s. I think you might be able to drag movie files and drop them directly on the buttons (rather than drag them to the bar at the bottom)
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
I want to take my favorite movies and put them on an HDD
By Rjupiter in forum Newbie / General discussionsReplies: 18Last Post: 9th Oct 2009, 02:05 -
want to put home movies onto dvd
By shashgo in forum Newbie / General discussionsReplies: 2Last Post: 30th Apr 2009, 09:14 -
Question how to put several dvds on one DVDr
By jimdagys in forum Authoring (DVD)Replies: 7Last Post: 24th Nov 2008, 10:29 -
How many Divx movies should I put on one DVD+R?
By Hank Kinsley in forum Newbie / General discussionsReplies: 11Last Post: 17th Aug 2007, 03:39
