I just bought an ATI All-In-Wonder Radeon 32 meg DDR, but I can't figure out how to capture analog video from my Sony Hi8. Will someone please educate me?
Note: I have hooked the camera up, but what do I do next? What software should I use? I have tried capture with Ulead VideoStudio, but I just get the TV image, nothing about the camcorder.
There's probably an easier way to do this, but...
Open up the TV player, go to settings (the box with the check in it) and go in the scheduler. Set it to record from the appropriate jacks you have hooked up. I usually set to 2 mins in the future. When you see the ATI record window come up, start up the Sony. I use this method when recording to the pc (in vcd format) from my vcr. Ugly (the process, not the recording), but it works.
Of course, you can do the whole setup without recording to just test wether or not your getting video and sound.
Oh, and I almost forgot. The dabgum ATI card needs to have an audio cable from the audio-out to the audio-in on your sound card. Go figure. But it IS in the docs.
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
Capture problem with ATI Radeon HD 2900 XT in Wondows XP SP2
By redrock1 in forum Capturing and VCRReplies: 3Last Post: 21st Mar 2008, 02:03 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 02:24 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 03:28
