I tried to play a few of my svcd's on this player that I just got and the movies were extremely choppy. Do I need to back the bitrate down a little bit? Any suggestions would be nice. It seems like a great player if I can just get svcd's to play properly on it. Plus, with it being a 5 disc changer, I won't have to get up to change the disc. It is supposed to be compatible with VCD and one guy says that his worked with a SVCD burned using Nero. I used Easy CD creator 5 with Daemon Tools to burn mine. Anyway, any help would be appreciated.
I have this same player...and I too had the same problem. Then I found a guide ... How To play MPEG2(svcd) in Panasonic DVD Players ... apparently this is a variation of the VCD Header Trick I haven't tried the origonal header trick, but it should work. So...the player won't actually play SVCDs but it will play "MPEG2 VCDs"
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
Some XviDs play choppy on standalone DVD player, but absolutely fine on PC
By udaykhan in forum DVD RippingReplies: 5Last Post: 15th Jan 2008, 12:09 -
SVCD converted movie with choppy playback at the end on stand-alone player
By supernano in forum Video ConversionReplies: 0Last Post: 27th Oct 2007, 11:10 -
Burned dvds choppy towards end on TV Dvd player
By bendit in forum Authoring (DVD)Replies: 1Last Post: 14th Jun 2007, 15:55
