ive tried the hack which 'op' posted more than enough, and can not get the splash screen to change from the tesco's one :/.
is there any one out there with the bin already made up with a diffrent splash screen
thx in advance
can you help me find the original post on how to mod the image in the bin file please m8.
just found this info
Remove the tesco's background and replace it with something you actually want.
1. Take the image you want as your background and use it as the source file in TMPGEnc-2.57.41.146-Free.zip
2. Adjust the settings so that the output mpg is 720x480 and 22073(or slightly less)bytes.
3. Get hold of the original BANK30.ROM firmware from Tesco.
4. Open EZPatchV12.zip and point it to the firmware, the only patch available will be the background patch. Choose it and select the mpg you made before as the file to patch it with.
5.Save the output as raw.bin, not bank30. Then change the file name to BANK30.ROM.
6. Burn the new rom onto a CD and flash away.
sanyo xacti 1010 to br or avchd
By syeager in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 31st May 2010, 09:28 -
Heeeeeelp !!!! 5.1 DVD authoring
By Gusss in forum AudioReplies: 2Last Post: 12th May 2010, 12:55 -
Question about adding toner to HP Laserjet 1010
By jimdagys in forum ComputerReplies: 1Last Post: 8th Dec 2009, 08:21 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
Digitrex GK-1010 Region Free
By emphasis in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Nov 2007, 08:18
