I have a mpeg movie that is around 110 minutes long with a file size of 201,759kb. It wont rewind or fast forward but i wanna make it so I can do this. First of, is this even possible? And if it is, how do I do it? What programs will I need? Etc., etc., . On a minor note the audio is a tid bit out of sync with the video so I'll try to correct this also. Any help would be great. Thanks in advance.
we're gonna need some details. hoow did you author the vcd, etc...
If you mean this movie doesn't FF in your stand alone Dvd-player,
I might have a solution.
Did you burn with nero?
I did, when i had these problems.
I switched to VCDeasy. But to make it work I had to install new ASPI-drivers.
Since I've done this also my (s)vcd's burnt with nero DO Fast forward.
So try to install new ASPI-drivers.
you can get some here:
http://www.vcdhelp.com/tools.htm#burn
I believe i use the second one.
good luck with it! -
actually im trying to play it on my computer before i burn it. it plays fine it just wont rewind or fastforward. keep in mind im not talkin about playing in my dvd player right now. But as a note the file name in parenthesis says (asf) however the extension is *.mpg
Aegisub wont play mpg, converting using divxland causes problems
By denadel in forum SubtitleReplies: 2Last Post: 2nd Oct 2011, 04:36 -
Ripbot264 rewind issues
By Fulwell_mag in forum Blu-ray RippingReplies: 4Last Post: 2nd Jan 2011, 11:12 -
Fast Foward / Rewind xvid or mpg?
By fredfillis in forum Newbie / General discussionsReplies: 3Last Post: 8th Nov 2009, 04:06 -
Rewind effect in Premirer Pro 2
By cobra jet in forum EditingReplies: 0Last Post: 28th Nov 2008, 01:54 -
Help with Video Conversion wont rewind/fastforward
By picklepepper23 in forum Video ConversionReplies: 2Last Post: 6th Sep 2008, 20:28
