Ok, I know this has been asked and explained several times before....but after searching through forums for the last 5 hours, I am more confused now then when I started....I've just bought a pioneer 105 and am thinking about backing up some of my dvd's and ps2 games...I have read countless number of guides and which software I should use....some of the software is not available anymore ( eg Spruce dvd maestro )....I would really appreciate it, if someone could advise me which guide to go for and what software I would need...as there are that many guides, I am getting totally confused...I was looking at the guide for DVDXCopy, but then realised that this method seems really easy, but doesn't put the dvd onto 1 disk...I don't mind having to rip certain parts out of the dvd to put onto one disk, but am confused what software to use ( DVD Decryptor, IFOEdit, Vobrator, DVD-R Calculator, DVD2AVI, TMPG, Chapter Extractor, Spruce DVD Maestro, Gear Pro....the list goes on )
Cheers JohnJohn
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
confused , newbie (more like overwhelmed)
By fordman37167 in forum Newbie / General discussionsReplies: 1Last Post: 28th Aug 2008, 22:44 -
Newbie confused. PC crashes/does wild when I attempt to record
By rob1974 in forum Capturing and VCRReplies: 3Last Post: 25th Aug 2007, 09:16 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 12:42
