hi movielovers..
is it impossible to make a vcd out of a AVI file without converting it to MPEG..
i mean first you couldnt make a audio-cd without converting the mp3.s to wav but now you can. some codec or so right!
if anyone know if this could be done i would aprecciate an answer!!
all you programmers now have a challenge =)...
always go pirate::..
Short answer: NO
If you load your avi to a Wizard that spits out a VCD, that means that the Wizard did all the job of encoding and burning you would normally do separately (e.g. TMPGEnc and NERO).
Look at the WHAT IS VCD section on the left...
BeTa -
NO ,Avi's must be converted to a vcd mpeg1 standard. The only program I use (nero 5.5) let you drag avi's into a vcd session but when u are ready to burn it goes thru the process of converting your avi's to MPEG1 VCD (which could take hours). I wouldnt recommend it either. Nero is great for burning but its an average VCD encoder. I always use TMPGEnc its better than most commercial software.
And By the way with audio cd's , Mp3's that u drag into an audio session are always converted to wav right before they are burned to the cd in CDA format.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
converting mpeg to avi
By extremebeat in forum Video ConversionReplies: 1Last Post: 24th Feb 2009, 13:07 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27
