Hi All,
Can I use the Stream Processing feature in DVD Decryptor so I can choose the audio languages and just use IFOEDit to create my IFO files after the ripping?
Regards,
Jose Febus
Hi All,
This is the process I am following to rip my movies:
1. Rip using DVDDecryptor (Stream Processing Audio and Video) Watch out for the 1GB filedize in options!
2. Rename the files so they start as VTS_01_1.VOB
3. Run IFOEDIT , select Create IFO, load VTS_01_1.VOB as the first one and save.
4. Load VTS_01_0.IFO in IFOEDIT and press GET VTS Sectors.
5. BURN THE DVD!!!!!
I wasn't able to get WINDVD nor CinePLayer to play the files from the directory, but worked perfectly from the DVD-ROM. But after burning the DVD (Using Pioneer DVD-RW and KHyperMedia DVD-R media) all I got wat choppy video jumping from chapter and completly unviewable!
Can you please tell me if I am missing something?
Regards,
Jose -
i used ifoedit for the first time the other day, i used dvddecryptor to give me an .ac3 file and an .m2v file. in ifoedit i click author dvd, drop in the video and audio, let it go and rewrite the files (took about 30 mins) and then burn the resulting directory. easy.
Hi flaninacupboard,
I tried that but my .vob files are jumping like crazy. I open the .m2v file and the video is ok, but the .vob files created by IFOEdit aren't.
Any hint?
Thanks for the help!
Jose -
jfebust:
jfebust - you missing a step....in step 3-4
Here's a guide at doom9.net to walk you through the DVDRipping process
http://www.doom9.org
Click on the link "The Guides" and there are a lot of step by steps guides there for you.
Good Luck!!!!!
It works great for me all I'm using is DVDDecrypter and IFOEdit then Nero to burn. Awesome guides!!!!!
Copying DVD's with Shrink and decryptor
By LeeRobertE in forum DVD RippingReplies: 6Last Post: 26th Feb 2011, 15:46 -
DVD Decryptor with newer protection schemes?
By Huh...What? in forum DVD RippingReplies: 7Last Post: 26th Aug 2010, 09:34 -
DVD Decryptor Error Massage
By pchan in forum DVD RippingReplies: 13Last Post: 18th Jun 2009, 14:37 -
SONY AW-Q170A Ripping tops out at 3x with DVD Decryptor
By alwayssummer in forum DVD & Blu-ray WritersReplies: 3Last Post: 29th Oct 2007, 19:08 -
Time to finally put DVD Decryptor to bed...at least for Liteon recorders...
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 4th Oct 2007, 13:55
