I took a 25.00divx encoded it to 23.976 using tmpgenc with do not framerate convert option, stretched the audio, multiplex, etc. Perfect mpg VCD playback on the comp by windows media player 9. Burn to VCD(nero) put in standalone. Plays well but then it will suddenly speed up thus getting out of sync. Then it will slow way down to get back on pace. Usually happens only at fast motion scenes but only some of these scenes and sometimes in just slow scenes. What could be the problem? I even put the cd in the pc still works great. I am thinking possibly a fault of the standalone not correctly playing NTSC Film framerates? Does this sound reasonable? Any other ideas
Oh yeah it also has blocks of red and blue in the background on and off during the movie, again only on the standalone. I cant really explain it better than that. They are somewhat faint but easily spotted at the same time. What do you think? Bad video file? it doesnt have this stuff on the computer monitor. Also the DVD player is running through an RF modulator to the tv if that could affect anything.
I could use some help. i am leaving tomorrow and will be away from a computer for awhile
25fps-source Ac3 to 23.976fps
By Lastman369 in forum AudioReplies: 47Last Post: 26th Sep 2014, 03:19 -
[MKV] 25fps to 23.976fps? Tried and failed. Help!
By lag in forum Newbie / General discussionsReplies: 15Last Post: 20th Aug 2014, 13:27 -
NTSC HDTV is usually broadcast at 23.976fps, yes?
By Gew in forum Newbie / General discussionsReplies: 38Last Post: 21st Feb 2010, 19:56 -
25fps to 23.976fps
By Charmer in forum AudioReplies: 19Last Post: 8th Aug 2009, 11:41 -
converting 25fps to 23.976fps
By pannivas in forum AudioReplies: 1Last Post: 3rd Aug 2007, 17:49
