Is there a big difference between VCD and SVCD audio/video quality ?
Results 1 to 14 of 14
This has been discussed many times before, I suggest you use the Forums
Search option, either way, some say it does, some say it doesn't, you are
the only one who can tell how it looks for you.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Video quality, yes because SVCD supports a higher video bitrate and approximately 2.72 times the resolution of VCD. Audio quality can be better also, but the difference may not be as noticable as the video quality difference.
A "well-made" SVCD will look significantly better than a "well-made" VCD on a standard sized TV.
There is, of course, no limit to how bad a "poorly made" disc of either specification can go...
Regards.Michael Tam
w: Morsels of Evidence -
I'd like to disagree on that, I have a store bought SVCD and ii've noticed no
quality difference over the store bought VCD I have. Quality depepnds on a
lot of factors, including your TV and DVD.Email me for faster replies!
Best Regards,
Sefy Levy,
I wouldn't say that a "store bought SVCD" would necessarily be "well made"...
Certainly, MY SVCDs look a lot better from MY VCDs and I consider both to be "well made". I have a pretty old TV too...
Regards.Michael Tam
Sorry, till I see a "well made" SVCD, i'd still stick to VCD, I don't see any
difference between the two, and SVCD takes longer to make, requires alot
more optimizations, and is less compatible.
Therefor for me, VCD rules, I evne got a Portable VCD/MP3 Player, how
many SVCD Portable players exist ? it's rare and expensive.Email me for faster replies!
Best Regards,
Sefy Levy,
PM me your e-mail. I have a few samples I can show you so you'll understand why VCD generally speaking sux in comparison to SVCD. Or just reach me at oldelrocho@hotmail.com
/Wizeman a.k.a. El Rocho of the Movie Madhouse"I have not failed. I have only learned what does not work."
-Edison -
I Sincerly doubt you'll be able to do so, maybe on the PC it looks better, but
not on my TV, absolutly no difference.
my email is sefy@myrealbox.com feel free to try and prove me wrong.Email me for faster replies!
Best Regards,
Sefy Levy,
I generally prefer making VCDs as well actually...
However, I can definitely see a difference. On my TV at least, the difference is night and day.
My VCDs at best look like new VHS. A top end SVCD is difficult to distinguish from DVD (on my TV).
Regards.Michael Tam
I believe there is a difference but how much depends on the film you are using (in my experience), some films I have encoded there is very little difference in quality but others there is a noticeable better image with SCVD with less pixelisation than VCD.
I dunno...it might work -
Personaly I think quality depends alot on the playback and viewing
equipment you are using, i've got an old Pioneer 525 (5 years old) and
a near 8 years old 29" TV, so I don't think SVCD would look that much
impressive for me.
Besides, i'll always prefer VCD, if I want higher quality, i'll buy the DVD.Email me for faster replies!
Best Regards,
Sefy Levy,
Personally I use both formats. It depends on the length of the movie. I never use more than two CDRs for my encodes, so for a long 2.5 hour movie, I have no choice but to use VCD. For shorter 90 - 100 minute movies, using CCE 4 pass VBR can give outstanding results. Using SVCD for any movie over 120mins is a waste of time as the results can look worse than VCD, (unless you use 3 disks of course).
In then end i think its up to the individual
Like I said in my first post, this has been discussed before, and no one who
liked VCD will switch to SVCD, and no one who likes SVCD will switch back
to VCD.
Things I was quality for, I buy the original, I got the Superman Movies DVD
Transformers DVD's, Battle Of The Planets DVD's, and others, cause when I
want quality, I prefer to pay for it.
Since i'm very satisfied with VCD, and I even saw it looked great in my eyes
on a brand new 34" Sony (Crap) Trinitron TV, i've got no problems with VCDEmail me for faster replies!
Best Regards,
Sefy Levy,
HD versus DV
By uno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 10th Mar 2010, 14:24 -
16 x 9 versus other formats...what to do?!
By twersk in forum Video Streaming DownloadingReplies: 3Last Post: 6th Mar 2010, 12:46 -
HDMI versus Coax
By SCDVD in forum Newbie / General discussionsReplies: 4Last Post: 25th Nov 2007, 00:26 -
16:9 Versus 4:3
By uno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Sep 2007, 05:35 -
NTSC - 29.97 versus 30 fps?
By SCDVD in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2007, 11:27
