Hi video people.
I recently came across a strange situation. I had a 5' long uncompressed AVI file which I tried to encode using Panasonic MPEG Enc 2.3 stand-alone. The file was about 2,5GB in size. I tried many times but the resulting MPG file was always shortened by about a minute or so.
I then had the idea of compressing the AVI using Premiere and the resulting file was just above 800MB. I fed Panasonic this smaller file and the MPG was just right this time, no part was cut!
Does this mean that Panasonic can't proccess files bigger than 2GB? And is there any trick around this?
Thanks and cheers to all
I don't know about v2.3, but for v2.51 you can do the following:
If you have the stand-alone version, you can actually load multiple AVI files and encode them all as one MPEG (it's in the batch options).
If you have the plug-in version, you could just load up the AVIs on the Premiere time-line and export it.
Regards.
Michael Tam
w: Morsels of Evidence -
Third option.
Load the large AVI into VirtualDub and frameserve to panasonic.
The Panasonic encoder does have the standard 2 gig file limitation on AVIs. The VirtualDub multi segment capture and frameserver is about the best way to get past most of these size limitations.
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
virtualdub won't encode anything
By johnr283 in forum EditingReplies: 5Last Post: 17th Sep 2009, 21:33 -
FFMPEGX won't encode!
By Kalasin in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2009, 12:02 -
Which one is better? Shrink 4GB movie to 2GB MPG or 2GB Xvid?
By volam in forum Video ConversionReplies: 4Last Post: 13th Jun 2009, 02:20 -
help with eac3toGUI, won't re-encode file
By runLoganrun in forum Newbie / General discussionsReplies: 0Last Post: 6th Dec 2008, 18:32
