  1. Hi there!
    I have a small problem here: I have a movie in as .avi file (itīs divx I guess), with a size of 730mb. In order to make it fit on a 700mb cd rom, I would need to trimm it down to at least 712mb. Taking a look at the movie I could take off a bit from the beginning and about 3 minutes from the end... this would hopefully make the movie smaller - BUT - which programm do I use to do this? Can I just open the file, trimm and then say "save" or do I have to code it again?
    Really apprechiate your help on this one, as I have actually two movies left that I would put on cd, (unfortunately my cd burner does not support overburning... )
    Mar 2002
    United States of America
    VirtualDub can do that for you without re-encoding again:
    http://www.vcdhelp.com/virtualdubedit.htm
    Hope That Helps!!! :P
