Just wanted to ask and see if this will work before buying the drive. I have a laptop with a 15G hard drive and want to capture from my digital camcorder to the hard drive to edit the video. Obviously it would be better to have a second hard drive to capture the video instead of the primary. I have a firwire card for the laptop to capture the video and I want to add a firewire hard drive. Can I buy a western Digital HD and buy a firewire case off the internet for this to work? I just bought a Western Digital HD for my PC and installed it and had to run software from a floppy for it to work, so I am not sure it is possible or not.
Yes u can certainly do that, but be warned u won't get ATA-100 speeds.
yes you can do that but dont waste your money buying a WD hard drive with 8 meg cache -- with external firewire case , get good case and good powersupply with it .. fan good idea also ..
a 5400rpm 180 gig or 120 gig drive in a case works fine in your application and will not get so hot for long writing periods ..
of course a faster rpm drive not a bad thing either - but your not going to really see the speed benefits through firewire .. -
What is ATA-100 speed ? Can you post results from some test ? I can try to put my new 120GB Maxtor (7200rpm, 2 meg cache) in FireWire case and compare it.Originally Posted by Greg12
Setting Up Potplayer
By Moontrash in forum Software PlayingReplies: 48Last Post: 29th Sep 2019, 12:57 -
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 21:32 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
Setting up my equipment...?
By Gun in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2007, 13:41 -
which setting should i use
By fruitpassion in forum Video ConversionReplies: 4Last Post: 23rd Aug 2007, 20:58
