Hi can anyone help, I have just brought a Xenius DVD player from Powerhouse for £49.99 and wonder if there is a multi region hack available. or can i make it region free.
Thanks in advance for any help
Timmylad
For the Xenius DVD1030:
Switch on with empty tray.
Press MENU then 1 6 7
A menu will appear to allow selection of region (1-6)
Select required region, or for ALL REGION press 0
And thats it !!
Or you can do this:
With no disk on the tray, press the MENU button.
Then press 1,6,7 one after another.
It will show a box asking for region number from 1-6.
Press the number desired.
I haven't check if it only works with a limited number of times. I couldn't find the key for multi-region.
Bye and enjoy it!!!
I found these on the DVD Hacks section of the site. I entered the word "Xenius" in the search field. You can take a look at it once in a while for updates.
Help with LG RC389H DVD player hack
By nannon in forum DVD & Blu-ray PlayersReplies: 7Last Post: 20th Jul 2010, 06:04 -
DVD Player Hack
By jgibson in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2010, 20:48 -
NON-region DVD player hack...
By cwb in forum DVD & Blu-ray PlayersReplies: 10Last Post: 24th Sep 2009, 17:53 -
dvd player hack seems to have gone wrong, any help?
By johnkurtz in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th May 2009, 16:09 -
How to stealth port 1030?
By alegator in forum ComputerReplies: 4Last Post: 7th Mar 2009, 08:43
