I have search about this and I have found very different opinions
Lets ask it in another way:
Between how many frames/ms do you interleave the audio?
I want to know what is the optimal setting
IrYoKu -
ok I will do
I have seen that with uncompressed AVIs, interleaving difficult a LOOOOOT the reproduction...
But with compressed this might be a different history -
I interleave DivX with CBR and ABR audio at every frame, but for AC3 I use 64-96ms, and check for proper playback.
Audio File Size Calculator
By onesikgypo in forum AudioReplies: 1Last Post: 13th Sep 2010, 09:14 -
Audio / Video interleave Adobe Premiere Pro CS3 problem
By mkrmec in forum EditingReplies: 5Last Post: 21st Aug 2008, 07:28 -
file size after stripping audio from DV
By dADDo in forum AudioReplies: 6Last Post: 10th Mar 2008, 22:58 -
Strange audio size issue.
By mijman in forum DVD RippingReplies: 1Last Post: 16th Jan 2008, 07:42 -
Which Interleave value should i put???
By X_Splinter in forum AudioReplies: 5Last Post: 17th Dec 2007, 11:58
