loveo,
I've made a BIN/CUE with TSVC. When I burn is with fireburner is works, but the prog crash a lot so I used 7 CD's to get one right.
Now I tried CDRWIN with te same BIN/CUE. The burning proces went fine, but my Pioneer DV343 things it's a audio CD. After putting te CD in my PC it seems that there no directory on the disc and even cant't see the files.
Somebody knows a solution???
Milko
Check the bin file and make sure it has the right amount of mb so that you know the whole movie is in the bin file. You could always remake the bin and cue file to rule that out. Sometimes for reasons i don't know my bin file will come out to be 0 bytes.i usually just redo the bin/cue file and all works out.
CDR-Win will burn gibberish if you used a pirate serial number (that it knows about).
Perhaps this is the issue?
Regards.
Michael Tam
w: Morsels of Evidence -
On 2001-08-29 07:18:50, lemmy999 wrote:
not if the pirated number was from a good key gen!!
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Obviously.
Regards.
Michael Tam
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Burning SVCD At 480 x 272, 1152 kbps ?
By Tham in forum Authoring (VCD/SVCD)Replies: 2Last Post: 16th Sep 2010, 14:21 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 08:25 -
Burning vcd/svcd full length film.........
By marcgarcia in forum Authoring (VCD/SVCD)Replies: 2Last Post: 15th Oct 2007, 20:07 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 09:06
