I try to open my Divx movie in VirtualDub 1.4.13 and I get the following error message:
"VirtualDub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 41720 ms of skew from the video stream. If this is unacceptable, decompress the *entire* audio stream to an uncompressed WAV file ad recompress with a constant bitrate encoder. (bitrate: 122.2 +- 17.6 kbps)"
The +- are on top of each other by the way. Anyway, when I extract the audio to an uncompressed WAV, the audio is about 4 or 5 seconds shorter than the video is. Is this going to cause a syncing problem? I'm guessing it will. Can someone explaing to me simply how to fix the problem and what tools I need to fix the problem. I want to make an SVCD that is in sync with the audio. TIA!![]()
wow--you replied to your own post twice in 7 hours
you need to be a little patient
try here: http://www.vcdhelp.com/forum/search.phpwhat are you askin' me for...
I'm an idiot!
DivX Converter Audio Problems
By maccool111 in forum AudioReplies: 3Last Post: 28th Mar 2010, 03:47 -
Cant seek my encoded divx avi's with HW players ... plz help
By samykoka in forum Video ConversionReplies: 2Last Post: 17th Mar 2009, 13:19 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
How do I convert DVD movie to DIVX w/o Audio Syncs problems
By peggypwr1 in forum Video ConversionReplies: 10Last Post: 1st Aug 2008, 17:22 -
Audio Problems with divx,xvid etc on dvd player
By iain123 in forum AudioReplies: 6Last Post: 30th Jun 2007, 14:57
