I just captured a avi file format with Adobe Premier 6.0. I need to conveert it to SVCD. I tried TMPGEnc and it does not reconize the file format.
Could use some help.
A little bit more than an answer to your request. But you need to have installed the Canopus DV codec to be able to use AVI with TMPGEnc.
I use a Canopus ADVC-100 and software which came with the box to capture AVI (Canopus DV format). I just use TMPGEnc to convert right from this format to VCD, SVCD, CVD and DVD with no issues. Unless you are doing some major editing I wouldn't recommend Adobe as it's a little bit overkill. Equipment that I am using for just video/audio stuff is:
HP 1.8GHz, 512 Mb internal memory, 200 Gig HDs (120/80), generic 64 meg video card, Canopus DV Raptor Firewire card, HP CDRW burner, Pioneer 105 DVD burner and external Canopus ADVC-100 Analog to DV capture box. On this machine using Win98SE (but use XP on other machines). For captures use DTV Satellite source to Canopus ADVC-100 via svideo connection.
For VCDs- Captured AVI is converted to VCD using TMPGEnc then burned with Nero. (using external audio SCMPX & Lame for audio / frequency conversion)
For SVCDs - Captured AVI is converted to SVCD using TMPGEnc then burned with Nero. (using external audio SCMPX & Lame for audio / frequency conversion)
For DVDs - Captured AVI is converted to DVD using TMPGEnc splitting Video and Audio. Converting audio to AC3 using SoftEncode. For a plain capture with no chapters/multiple videos use InfoEdit to author DVD. For more complex video (Camera DV / multiple videos) use Spruce Up to author then Nero to burn. Always burn to a DVD RW to validate then finally to DVD-R to keep. These are to play on US purchased DVD players.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
ADVC 100 file size
By Honda617 in forum Capturing and VCRReplies: 8Last Post: 27th Jul 2010, 23:47 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 01:23 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 08:15
