    May 2001
    Im using the latest version of dvd decrypter. There is a part where you can select main movie to put on a dvd. The problem is I rip the main movie feature and I cant put it on to dvd and have it playable. Any suggestions. Please dont suggest I read the guides etc. Ive looked and cant find anything that relates to dvd decrypter. Thanks
    Feb 2001
    Macondo, Puerto Rico
    Hi,
    Are you ripping the video_ts.bup, video_ts.ifo and the video_ts.vob?
    You need those too....
    Regards,
    Jose
  3. Member wulf109's Avatar
    Jul 2002
    When you rip the main movie with DVD Decrypter it does not create a correct set of ifo files. You need to use a program called Ifoedit,it has a create ifo file function that will create a set of four ifo's from the vob files you ripprd.
    May 2001
    I tried using ifo edit .91
    It created a Video Ts Ifo file, Vts 01 0 Ifo, vts 01 0. bup, Video ts.bup,Video ts 01 0 vob-04 0.vob. The rip of the original had 4 vob files. The question i have is it created ifo files but it wont play on my computer. It opens up with the dvd player, but doesnt play. Did I do something wrong?
  5. Member wulf109's Avatar
    Jul 2002
    All files must be ina directory named VIDEO_TS. I use PowerDVD,select open files on the HD. Navigate to your VIDEO_TS directory,open it and select video.ts.ifo and it should play it just like it was a DVD disk.
