okay i have been reading through the last 50-100 posts and have not seen a clear example or best way to get a dvd to 1 dvd-r. From what is sounds like there is no program that will automatically do that because dvdxcopy wants to put the movie on 2 dvd-r's. Is that correct? So then I am stuck with reencoding the movie once it is ripped? Is that correct? Is reencoding the movie the ONLY way to get a dvd to 1 dvd-r? Is it best to rip the movie the old conventional way using smartripper, dvd2avi and then tmpge? Is there a faster or better solution with less steps?
I want to be able to take a movie and put it on 1 dvd-r in case anyone was wondering.
Thanks in advance
bt
Results 1 to 9 of 9
Hello,
I have found that using a guide called dvd for dummies (there is a link to it under links on the left side of the screen) works well for me. it only gives you the movie but I never watch the extra stuff anyway. give it a try, ill think youll agree -
Hello,
change that, the link is under dvd_rip under the how-to section. It is called dvd 2 dvd r for dummies. -
If you need just movie and not rest of the DVD (menus, extras) you can use guide in www.doom9.org . It worked for me. (Not all movie can fit even after removing extra sound and subtitles)
Hello,
yes you do get the chapters but the dvd auto starts. the chapters arent listed but you will be able to fast forward to each chapter. -
okay thanks for the suggestions fellas
this is where i am getting stuck at
i ran the dvd2avi software
once that is done I open tmpge 2.53, I also have 2.58
anyway i am unable to open the video file, but the audio file loads fine
i get a message saying file cant be open or is unsupported. I can only see the .d2v file if i choose show all files on the bottom
any idea why i am getting this?
thanks in advance -
Why do you re-encode ?
Try this ... Creating a DVD that contains just the main movie -
If your using the guide i suggested you dont even load the audio because you dont mess with it. if you havent tried it you really should its easy and it works well. i did it to do spiderman and it turned out perfect. it fit on one dvd+r (its a two hour movie) and it has the 5.1 sound. it really is easy, but read it first and get familiar with it.
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 17:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 08:59
