I need some expert's help on creating a DVD disc. I exported a project from Premiere to 6 MPG2 file for a total length of 45 minutes. I then use MYDVD try to author the disc. However, after a while, MYDVD complains about data exceeded multiplexed bit rate. What does that mean? Has any one seen this? I went back to Premiere and exported to the MYDVD format, which is *.m2v and the *.wav file. MYDVD complains the same thing. Can anyone help? Thanks,.
The total bitrate of your video, audio and subpicture streams plus multiplexing overhead can't exceed 10080 kbps. For your example that works out to:
Code:10080 kbps maximum multiplexed bitrate - 280 kbps multiplexing overhead ------ 9800 kbps max elementary stream bitrate - 1536 kbps audio bitrate (PCM Stereo *.WAV) ====== 8264 kbps video bitrate (MPEG-2 *.m2v)
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
Bit Rate
By shapper in forum Newbie / General discussionsReplies: 10Last Post: 2nd Jun 2008, 14:04 -
The Best Bit Rate For DVD's...
By GRAMOPHONE in forum Authoring (DVD)Replies: 2Last Post: 23rd Apr 2008, 22:37 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
the right bit rate
By nojee in forum Video ConversionReplies: 5Last Post: 10th Nov 2007, 03:00
