Hi
With 2 movies i got a green screen, i can see the movie is going on behind the green blur, but how do i get that off, ??? i tried with gspot but it says that i got all the codecs and it is just fine BUT IT'S NOT
Please help me ??????
And i got the newest nimo pack and all the codecs ai is only theese 2 films that is a problem
I had a similar prob with a film, 3 quarters of it was green and you could see the film trying to play in the background. Uninstall the nimo codec pack and only install the defaults and experiment with the extra ones as some of the codecs will conflict with other ones causing the Green screen. I done this and now my film views ok.
Hope this helps. -
NOW I know the solution to this shit.
I uninstalled all DivX codecs and xvid codecs.Then I Installed only xvid to test if it worked and it did but with no sound cause it had ac3 sound.
You can install xvid codecs from here:
http://www.divx-digest.com/software/xvid.html
Then I installed all DivX codecs separat (Not from Nimo).
http://www.divx-digest.com/software/divxcodec.html
After that I installed Nimo Pack but unchecked all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow 2002-04-19.Install Nimo from here:
http://www.btinternet.com/~nimosiro/
Now all should work fine!
By the way,AC3 comes with the Nimo Pack. -
Sup, I have been having the same problems, and i just did what crack_man said to do, and everything is fine now. So go do what crack_man says to do and you should be fine as well.
TMPGEnc green screen
By BobAchgill in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2010, 16:06 -
How to use green screen with video?
By MitchStevens in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jun 2009, 19:33 -
By MitchStevens in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Jun 2009, 09:44 -
Underwater Green Screen
By kccannon in forum EditingReplies: 6Last Post: 21st May 2009, 19:35 -
green screen in convertxtodvd
By fruitpassion in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jun 2007, 00:16
